Disables the current ports associated with the given This command is available on all Universal switches supported in this document. ID.
| mlag-id | Port associated with MLAG. |
| mlag_id | MLAG identifier value of the MLAG port. Range is 1–65,000. |
N/A.
If any ports are added or deleted from the LAG, the port state for those ports is not changed.
In MLAG orchestration mode, this command is executed on the other MLAG peer before it is executed on the MLAG peer on which the command is run. In orchestration mode, if the MLAG port numbers are not same on both the peers, it is possible that a different set of port numbers are disabled on the different MLAG peers. This command helps ensure that the correct set of ports associated with the MLAG ID are disabled.
If the port associated with the given MLAG ID is a load shared port, all the member ports associated with this load shared group are disabled.
If the port associated with the given MLAG ID is a virtual port, the command is ignored.
# disable ports mlag-id 123
This command was first available in ExtremeXOS 33.1.1.
